Quick question on the whether or not the 1236T has enough power to get a good finish using CNMG or if I need to stay with CCMT. After recently switching from a 10" to the 1236T, I am taking my first venture into insert boring bars and see more insert tooling in my future. I would prefer to stay with as few insert styles and sizes as possible. I have looked through about 20 threads and can't find a minimum HP for a smooth surface finish for both steel and AL. I've only come up with a SB 10" is too small and 16" 5HP works great. Thanks in advance for the newbie question.
Ccmt vs cnmg
I was going to purchase some boring bars to be used on a CNC Gang lathe and was set on buying 3/4 shank bars that would use the CCMT insert. After considering it, I am now thinking that the CNMG might be better as you get four cutting edges vs 2 for the CCMT. What would be a benefit of one...
www.practicalmachinist.com
Just ordered a new multifix tool post and am looking at getting some indexible tooling for my South Bend Heavy 10 lathe. I think I'm leaning towards CCMT or CNMG so I can use one insert for external and boring operations. I know CCMT is often recommended for smaller lathes due to it's positive rake, however the SCLC holders you use for them are actually flat with no positive rake at all. It seems all of the positive rake is built into the insert it self. On a CNMG the tool holder is tilted down for negative rake so you can run a zero clearance insert, but the inserts seem to have a similar...
- Lucas E
- Forum: GENERAL HOME MACHINE SHOP DISCUSSIONS
