The press arrived. Typical rough Chinese castings and fit, but it’s got an important extra 1-1/2” of working height compared to the standard Dake No. 1-1/2.
I spent a good couple of hours going over it with a file and taking parts to the belt sander for deburring. That made it a lot easier to handle without blood loss, at least. This picture shows the easing of the corners of the daisy wheel.
The front bearing plate has an inserted piece of sheet steel to act as a wear plate.
To that, I added .020 brass shim stock to provide a smoother wear plate.
I then oiled it and adjusted the gib screws. I left it with just enough tension to remain in place when I raise it using the hand wheel, but can lower it with my finger on top of the ram. That gives it about 1/32” of wiggle at the bottom of the stroke.
Beyond that, it just works. Can I get 3 tons of press force? With 20:1 mechanical advantage, it would take 300 pounds on the end of the handle. I weigh 200, so, no, not without a cheater pipe. But I think it will meet my needs.
Rick “now to find a place to mount it” Denney
