What Did You Buy Today?
And took some photos of his vise as the one I bought is missing the spring and a wedge. I will need to get some spring steel to make that…
It's counter-intuitive, but you don't really need spring steel to make the spring for a leg vise. Mild steel works perfectly well and is easier to forge into shape. I've refurbished maybe 20 leg vises with new springs and wedges and I've made the spring out of mild steel on some and spring steel on others and there isn't any difference in function. I go by what stock I have that's closest in size to what's needed.
Good to know…
I need 1/4” or 5/16” x 1-1/4” x 12” to make it and was about to order this stress resistant 5160 steel because I could not find spring steel that thick…
Good to know…
I need 1/4” or 5/16” x 1-1/4” x 12” to make it and was about to order this steel resistant 5160 because I could not find spring steel that thick…
The link didn't work for me, but 5160 would certainly work. Most car springs are 5160 so that's how a lot of folks source the thicker sections. A buddy of mine put lift kits in his and his friend's diesel Excursions a few years ago and they gave me all the factory leaf springs from both, so I've got a big pile of it!. It's good stuff, but it's a lot harder to forge/shape than mild steel (even in the same thickness). You have to work it hot to prevent cracks from forming, so a bright cherry to orange or even lighter. The first time I tried forging it I got a 1/2" round piece yellow hot, hit it with a hammer and made a pitiful little dent...I was like what just happened? :grin:
Good to know…
Your link didn't work for me as well. My legs vise is missing the same parts and 1 or 2 more. Really looking forward to what you end up doing.
Gman I appreciate your input as well. Hopefully when the vise floats it way to the surface of my repairs list I will remember your input. Thanks.
Link fixed in my original posting. Should have read stress resistant steel
Oh boy! It will be a real task making that 90 degree bend!!!
That's just common 5160 spring steel...not sure why they've added the "stress resistant" description. There are actually quite a few spring steels...for example, 1080 (piano wire) is a spring steel as well and often used to make knives, just like 5160. 1095 is one of the most common knife steels and is also a spring steel. I wouldn't buy anything to make a spring for a post vise if you have mild steel the correct size...not noticeable difference in springiness for something that moves as slow as a post vise.
I do not have that in stock... anything much really... and will be traveling... so I just ordered it. So it will be here when I arrive. I need to figure out how I am going to bend this into shape... I will start a thread on a rebuild for this vise and ask for suggestions there...
I don't tend to buy much as I'm trying to clear stuff out not add to it, but I bought some neat micrometers recently
The bottom ones was my birthday present from my family this year, the 1-2" I got at auction with the two in the second pic and the 2-3" I got recently off another forum
Indicating micrometer and an inside bore micrometer (0.4-1.2" I think). The indicating micrometer is neat as you set the measurement you want, press the lever to move the anvil away, insert the piece to be measured and then release the lever. The dial then tells you how many tenths you're off your mark. Used it a bunch for sorting gage pins
And not buying, but selling - this was what was left of my scrap and resharpenable carbide. I was getting $5-6 /lb selling it for resharpening in eBay, so called around and shipped it all off to these guys. Super impressive service. Mail lady was not impressed though :)IMG20230717164432.jpg
