- Apr 14, 2014
- 3,560
As long as it works and you position it carefully there shouldn’t be a problem. The main reasons for the15* is to be able to have the point of the diamond touch the wheel rather the the side of the diamond.
The 15* point placed a 7:00 will also cause the tool to be pushed away from the wheel should you try to lower the wheel too much. The 40* angle could cause the tool to get caught under the wheel tip it, and violently eject it.
I’ve seen incidences where a tool was misplaced and the magnetic chuck wasn’t engaged. The tool flew across the room and hit the wall. No casualties other than a broken wheel and damaged tool.
As a side note several companies make wheel profiling tools. They are often used at a variety of angles.
