- Jul 9, 2014
- 619
Seeing how this is about grinding the tool tip , I'd like to ask a question that has been puzzling me as I seem to have a mental block about something.
I have a QCTP on my old lathe
I want to bore an inch hole through some 2.5 " x 3 " long round M/S bar & at either end of the newly made " tube " I want to open it out to take a 1 &3/4 " OD sealed roller bearing unit that is 1/2" wide.
I've given it quite a lot of thought of how to ensure that the bearing will be secured and am going to use circlips but I can't quite visualize what sort of ground tip I need to make so I can clean out the recess so it has a 90 degree face to the turned 1 & 3/4 holes internal face . ( have no problems accurately using a grind stone )
I have some rather weedy boring bars hand ground to almost an off set round with a spade type tip on the end from 1/2" sq HSS bar but the cutting end face that would be at the internal flat face of the boring is angled to about 30 degrees and as that is a the other half of a thread angle I'm loath to alter it .
Can some of you more experienced guys sketch what sort of grinds I can put on some new 1/2 " square HSS bar for me to make this cutter , as I'm not sure if a simple grind of face and angling the QCTP a tad will suffice when it hits the back wall ?
