- Aug 19, 2023
- 1,158
I'd part brass using HSS. Use a 0.5" stick out of the blade. 3/32" thick blade. Should be pretty easy, even on a 7x lathe. Using carbide on brass, strikes me as just silly. Make sure you are on center line and the parting should go easy.
Don't knock it until you try it. It cuts brass very nicely. Very nicely indeed!
Recently made a blind cap nut from 20 A/F CZ121 brass and using a carbide H01 (aluminium) insert, it cut through it like a hot knife through butter. Even parting off was without the usual stress.
Don't misunderstand me, I am not against HSS tooling, I just prefer carbide inserts because the angles are perfect and I do not, at the moment, have time to grind, shape, and stone an HSS tool for a so-called "quick" job where making the tool would take longer than making the part.
