With all the parts done I could finally start to install the ball screws, bearing blocks, servos etc.
In order to tension the z-axis belt during the installation I used two bolts with long nuts.
The quick connect fitting for lubrication of the Y-axis ball screw nut clears the casting by a few millimeters using the little adapter I made.
The use of feeler gauges simplified the initial alignment of the X-axis ball screw nut mount.
At this point it was time for another side project again as I realized that the nut on z-axis trapezoidal screw wasn't aligned properly when the mill was assembled at the factory.
The head of this machine is quite heavy so I instead of removing it altogether I rested it on the table of the machine using a few wooden blocks.
I then moved the table forward until I could reach the bolts for the nut.
With that done I had to go through the laborious task of the aligning the head which always takes a while.
