With the parts for the X-axis done it was time to focus on the Y-axis. I didn't have all the measurements for that axis so I had to take apart the machine in order to get them.
Took a few measurements and made a drawing in FreeCAD. After a few attempts I had a drawing matching the stock mounting holes.
This is how the 3D model in FreeCAD looks for the Y-axis bearing block mount.
While I had the machine apart I decided to install the central lubrication stuff I've had laying around for almost two years. This took quite some time as I had to do the oil retaining grooves by hand using a Dremel...
Next up was drilling the holes for the oil line connectors.
I also added for bolt holes for the Y-axis ball screw nut mount. I added these in advance so that I hopefully wont have to remove the saddle when the time comes to install the ball screw.
Then I started assembling the machine again and installing the connectors for the oil lines. I really like these stainless push in connectors, I bought them on AliExpress from this store:
https://www.aliexpress.com/item/1005002771044559.html
While I had everything apart I remembered that I needed to redo the drain for my flood cooling.
Previously I had the drain from the table go down to the top of the stand and then through a filter there and on to the tank at the bottom of the stand.
However after a little flooding accident when the filter on the drain from the top of the stand got clogged and coolant overflowed on to the shop floor I decided to change the setup to prevent that from happening again.
I now have a direct drain from the table down to the tank while at the same time retaining the drain from the top of the stand so that the oil which seeps out from the lubrication drain down into the tank too.
This is how it looks from the outside with all the hoses installed.
