Next up I tackled the mount for the nut on ball screw on the X-axle. This ball screw is quite long so I knew this had to be very precise.
In order to verify that I had the measurements right in my drawings I printed the drawings and cut out a few of the holes so that I could test fit them on the machine.
These first drawings where made using Visio but half way through I realized that these parts needed proper 3D models.
So I sat down and spent an afternoon getting the hang of FreeCAD which was surprisingly easy to get started with for this type of smaller parts thanks to all the very informative tutorial on YouTube. The
MangoJelly Solutions YouTube channel really deserves to be mentioned here as those tutorial are top notch!
The piece of stock I had ordered for the mount was quite large so it took a while to remove material before I got down to final size.
Once down to final size I needed to do a very precise 40mm wide and 60mm deep hole through the center.
Plan A was to use a rather crappy Chinese boring head.
However the tooling that came with the boring head proved to be very dull and fragile so I went on to plan B, the rotary table.
However no I came across another problem, mill deflection. The long 16mm Sandvik end mill deflected to much (given the 60mm depth of cut) which made the hole slightly conical.
So on to plan C using a friends lathe with a 4-jaw chuck mounted in a 3-jaw chuck, unorthodox but it worked
With that done I could do the final operations.
The top of the saddle on the machine was actually machined to a pretty good tolerance. I removed the paint from the surface and stoned it very lightly.
I made the mount about 0,15mm narrower than then gap in the saddle and it gave a very tight fitment but still allows for some adjustment.
Here it is with the ball mounted for a first alignment.
With the ball screw mounted and aligned I could take the measurements required to finalize the design of the mounts for the bearing blocks and the ends of the table.
Next up is to print paper templates for these models and verify that the measurements and design is correct before I start milling them.
