I got the oil for mill and changed it today.
I've had oil drips run down the outside of the machine a few times and newer figured out where it was coming from. But when I removed the fill plug I realized that it was the culprit. The was no copper washer on the filler plug and the breather hole led nowhere so any oil pushed out with the air just accumulated on the top of the machine...
To fix this I plugged the normal breather hole with a set screw, added a copper washer and then installed a hose barb on the top of the bolt.
I then added a small hose so that the oil will have a chance to separate from the air and run back into the machine.
I figured that draining the oil with an oil plug on the side of the machine would create a mess so I opted to drain the majority of the oil through the fill plug using this little contraption.
It worked very well and when I removed the drain plug there only a very small quantity of oil left which I drained using a small aluminum pipe taped to the side of the machine.
The magnet on the drain plug didn't look too bad given this is a new machine that has never had an oil change before. However the hole for the drain plug left a bit to be desired.
The mating surface around the plug seem to not be machined and the copper washer pushes against a painted surface. Also the hole isn't dripped/tapped straight so the copper washer ends up getting compressed on one side but not the other. That explains all the teflon tape on the plug from the factory...
The machine is noticeably quieter with the new oil which is nice.
I overfilled the oil to the top of the sight glass to see if it would reduce the amount of air that gets trapped in the oil during high speed operations. But I still get quite a bit of air in the oil after just a minute or so of operation. Maybe I should try to increase the oil level even further.
