- Aug 6, 2015
- 4,292
Motor is fine… General Electric 60Hz, 115Volts, 1/2 HP… si luckily I don’t have to buy a new one. I did run it before putting it on the trailer.. my mistake was not taking photos before I took it out…. But that does not matter now… I will figure out correct setup/install and do so…Regarding re-mounting the motor. Not something you have to be overly concerned with, but I made do with my 820 on a wide bench for a while the infamous "previous owner" (PO) put the lathe on . Getting to the motor bolts was a royal PIA. I have a small mill and made some tee nuts that fit the underside of motor shelf. Made a huge difference. If you consider replacing the motor, pay close attention to where a start cap may be on the motor, or if there is a wiring bulge, proper term is escaping me at the moment, on the case. They can make mounting some motors impossible. A fluid resistant wire housing from a home improvement center looks good IMHO, and is easy to keep clean.
I just need to install back after I clean and paint the base/stand.
In Ocala until Saturday night… so not able to do anything until then…
On another topic… against all logic and common sense… looking into a PWT Multifix tool post system… asked Peter for a quote for:
1 - System A Tool Post
10 - AD1675 Holders
1 - AV75 round adapter for squares holder
2 - AH1675 Holder
1 - AT2075L Parting Tool Holder with 26mm blade holder and carbide cutters
4 - Spare bolts for each parts of tools
