As beginners most of us don’t know very much about any of the intricacies of mini lathes. We read the product description and specs and look at the pretty pictures. All of which is communist propaganda BS. The description says the lathe can do metric and imperial threading. I’m sure it can but not with the gears and charts provided. If they had included 2 additional gears the lathe should cut all the common imperial and metric threads. The retail cost of those gears is about $10. Theres no cost to include accurate charts. I would have gladly paid an extra $100 and been happier with my lathe. It doesn’t make sense to me unless they’re playing a sick joke on the consumer.If the factory included true transposing gears this would be simpler, but they cost-cut.
Something to check carefully before buying
-Mark
im sure there’s thousands of others that’s had the same problem because I bought mine from amazon and they have them on eBay too. Of all those owners only 1 posted a gear chart. Nobody seems to want to help out the next fella anymore. You ask for help and you get told that you shoulda checked into that before buying or do some head scratching and figure it out buddy. I get it, the mindset of most is forget the next guy. He’ll have to figure it out the hard way. I was raised to treat others the way you would want to be treated so it’s gonna take me a little while to adopt these ways.
I appreciate your advice and next time I buy a lathe I’ll check carefully. Until then I’ll use the gear chart the one fella posted that covers the common threads. Smdh
