- Aug 19, 2023
- 973
At this point I'd be looking for a root cause to all the problems with your lathe. It sounds to me like something is intermittently seizing and you've perhaps been fixing the damage, but not the cause.
GsT
Change gear train train was the issue. Main cause was the 80/20 gear carrier sleeve siezing. Annoyed me a bit considering I lubricated it only the day prior as per my normal routine of preventative maintenance. The rest of what happened was just the knock-on effects that it caused.
That sleeve siezing is a known issue, hence why I pay it a lot of attention and ensure it is well lubricated but that did not stop it it siezing for some reason. As for fuses, well, fuses will be fuses and they fail anyway at any time, so not an issue. Apart from that, I intentionally use a low amp fuse in the plug. That little trick has saved a lot of equipment for me over the years.
Ran it for a while without load after sorting it all out and no problems.
