- Dec 18, 2019
- 7,208
There's tolerance and the like. I'd think that I'd defer to the OP's dimensions, because who knows what Vevor did. I made the dimensions close to nearest mm or .5 mm. With all of this stuff, there's going to be "some hand fitting required". Guess it's the nature of the beast. If it's slightly off, I can make another stl file for him to try, or a little judicious sanding. It's plastic, it won't take much to alter it if required.@WobblyHand
Not sure if this will help, but here is some info from a SIEG SC3 40T "POM" (Polyoxymethylene) plastic gear:
Keyway: 3mm wide, 2mm deep with 1.2mm of boss outside of that.
Centre boss: 18mm diameter by 7.6mm thick.
Gear is 7.75mm at the teeth
Seems odd to me that the boss is 0.15 narrower, but that is how it measured out and I did remeasure several times to confirm it.
Apparently, the workbench that I was using was replaced with something better. Anyways it only took 3 minutes to design the gear, so it's not a big deal to make another one. It's all extrusions and pockets to me.
