My new used eccentric shaft came in and is now residing in the head with the backgear on it and 2 new drive belts. Whoever worked on this before had no idea on how to install the parts. I think from the damage to the eccentric shaft and end cap bushing I would guess he used a Large hammer to beat the pieces together. I used a brake cylinder hone to remove the burrs in the bore for bushing caps. They had them on backwards and I think that's why they had to force them. Now the caps slide right in easy as they should be. Install the short cap in the rear first. Then place backgear with shaft into the cavity, then install the drive belts. Then put the rear eccentric shaft in that rear bushing. The little gear will probably fall off, mine did wrestling it in. One mounted I turned the headstock on its rear and installed the front bushing. Then lay the headstock on its side bottom facing you. Now you can slide the gear and shaft assembly to where it need to be. Push the bushings up to contact the shaft and then install the 2 socket set screws. The rear bushing set screw hole is also the rear headstock mounting hole. I ran a tap through all threaded holes before any assembly work.
Now I have the headstock setting where it goes except I have the rear set on some cardboard as that rear mounting bolt and the headstock clamp will not go on unless you elevate it about a 1/2 inch. So today I'll finish the mounting of the headstock and the install the new bushings for the Vbelt drive and cone pinion gear.
