- Apr 30, 2015
- 12,075
Sounds like the motor might be wired in reverse- The jog button should be the same direction as the normal forward direction. If not, then you are probably running on the reverse contactor for forward.
No problem- we can either fix that now or later. You need to show a close-up picture of the motor terminal board.
What is the power supply?
Amazon has contactors for less than 20$ each
