Bid you get the motor wired and running. If so, how does it sound when running under load? Reading the plate, you need a full 12gauge 20-amp circuit so it not blowing breaker. I'm retired electrician and wired a lot of them.
The new Leeson runs great. The GE that came with it also sounds great after I put new bearings in, but definitely needed more power than I had available
