- Mar 25, 2013
- 5,222
@Flyinfool -I should point out that making the relief in the Aux Base go 180 deg will NOT allow the spindle to pivot to both sides. Keep in mind that the worm is offset from the spindle by 90 deg so this would only allow you to rotate the spindle straight down (which is obviously not useful.)You are right. the Aux end may not need a plate. It can always be tried without a plate and one added if needed.
I have the new drawings for the aux end based off of a 2.000 diameter.
I have moved the worm assy in to 2.100.
I used the relief that was already in the Aux Plate to make a 180°sweep over the top so now you can rotate in either direction, also moved it in a bit to allow room for the housing.
I am still working i the 3D model and have not fixed the drawings yet.
Also, my change in direction will probably necessitate me moving the shifter so you might want to keep the direction as is.
