- Apr 30, 2015
- 11,382
Thank you for mentioning that manual posted by @RadialsYay! Way to go! I do this for fun, I used to do electronics work for a living
Big shout out to a new member Radials who posted a helpful Enco manual I hadn't seen before
I have this exact same lathe, Mark helped me repair electrical issues also.Terminal strip 0 to terminal strip #2 read 32.2V.
E-stop jumper connected to Power Start to #3 32.2V.
The wire nut with jumper turned out to not have wire from panel coming in. When I reconnected it the KM1 energized immediately. Apron switch works, lathes goes forward and reverse. It's just always energized unless estop is pushed in. If apron switch is left on and the estop taken off (twisted and popped out) it will immediately start running again.
