I started on the DRO installation. Came across the first issue which is that the cross slide scale will cover the cross slide locking screw
The instruction included were not very good, and the video from DRO Pros (which is very useful) avoided that topic. I did not want to loose the locking functionality so I emailed QMT/PM to see what the options were. They sent me a PDF that showed more details on the installation with a couple of "options". The solution that looked least invasive was to build a shim to hold the scales and reader head far enough away from the slide body that I could get a wrench in to the slot and lock using a hex bolt.
First order of operation was to produce a bolt that fit. I had on the right size but the wrong length. I cut it down to size and removed the thread "shoulder" near the head so it would be able to screw in closer to the body. Then I shaved a few thou off the head to make it have a lower profile.
After that I checked my wrenches and determined that 8mm of space would be enough, so to error on the safer side I decided to go with a 10mm thick shim. I would need to add the same height to the scales and the reader head, so I decided to start with a single bar of mild steel and square it, then face it down to 10mm thick and the correct width (28mm) to fit the scale (vertically) and the reader (horizontally). Once the piece was sized I cut 3 pieces (two for the scales at 23mm and one for the reader at 62mm) with my fancy power band saw (okay it is an inexpensive dewalt hand held unit but it does the job). From there I faced the ends and brought them to final size (21mm and 60mm). Then I milled a slot on the scale risers. Later today I will mill the slots for the reader riser.
I will most likely need to find some longer screws. Alternatively I could have mounted the risers and tapped them for the current screws, but I was thinking that I wanted the screw to touch the lathe rather than just screwing in to the riser. This way the riser is just a shim and not integral to the setup beyond adding distance.
