Thanks Ron- there's a method to my madness. I started knowing nothing about how a lathe works. I nkow have an iimate understanding of what is going on inside the apron when a control lever or half nut lever is changed.
Rick
i've got the head stock and drive gears reassemble and started oiling it up. Steve's manual recommends teflon grease for the spindle cone pulley and back gear shaft. The SB bulletin "Oiling the Lathe" suggests a few drops of oil in both of theses areas. What-s the best approach? If grease - how much
