[How do I?] Wiring Up Single Phase 220v Drum Switch To Motor On My Bridgeport
Yes, sir- i can make you a diagram
i can even do you one better, i have an extra drum switch lying around
if you want it, maybe we can trade something or work out other arrangements
you can email me :
ulmadoc@gmail.com
Hi Mutt,
I worked out the wiring diagram for the Square D Drum Switch
it will be there in a couple days
i apologize for the crude draft of the wiring diagram
i hope it is easy enough to follow.
give me a shout if you don't understand something
double check your connections before powering up
if the rotation is opposite of your preference after installation:
disconnect power supply
remove T8 from switch 3
remove T5 from switch 2
install T8 to switch 2
install T5 to switch 3
recheck connections
throw some 220/230vac to it and the rotation will be reversed of the last configuration
Looks easy enough. Thanks for all your help. I'll post some pics of every thing as I do the conversion, and make a parts list of every thing needed, in case someone else wants to do the same and switch over to single phase on their mill.
Hey y'all, can one of you bright folks help me wire in this drum switch? I will post it by pictures
First pic is the brand new Leeson single phase motor with adapter plate.
next pic is the wiring schematic on the side of the motor
next are the wires as shipped. This is wired as shipped for 220v
next are some pics of the new single phase drum switch
View attachment 138151 View attachment 138152 View attachment 138154
would someone like to help me out hooking up these wires to the switch? L1 and L2 are my 2 hot wires on my 220v plug. The load lines (T2, T3,T8,etc) are the wires from the motor. But what is 12?
Can you tell me where you got the adapter plate?
