- Dec 21, 2018
- 2,020
40 years ago I built a rotary converter, worked great. I came by a used 3 phase motor on the cheap. Bought some big caps, switches and relays and spent an evening putting it all together. Worked for years before I got real 3 phase. The rotary does produce "real" 3 phase but looses some efficiency. It will work with any (?) 3 phase machine you may get in the future within it's output range. (CNC????) No programing, doesn't care if it is a multiple speed motor, will drive additional motors at the same time, instant reversing of a motor isn't a big deal.
Static converters do not produce true 3 phase they only kick a 3 phase motor over using big caps to get it spinning. You can home build the same for way cheaper. BUT the driven motor will be a lot less powerful.
