- Apr 30, 2015
- 12,082
There's no advantage to running it on 220 unless you won't have 110 available- is that the case?
If so, then I would just test the motor without the switch first with a 220 volt source to make sure
the motor won't trip the breaker or burn up itself or the drum switch
The switch you have cannot interrupt both power line wires when off. Is that going to be an issue for you?
Some folks consider that unsafe with 220 volts. Not as big a deal for 110 since the neutral is effectively cold.
(if the house is wired correctly)
