- Mar 12, 2021
- 68
Isn't this what you're looking for?
Vise
Shop Shars Tool today and see why customers choose our high quality vises at a great value, same-day shipping, and dedicated customer support.www.shars.com
that's realistically what I probably will end up with
I cant remember the rules on posting links but the tegra 660U "style" was what I was talking about that seemed pretty interesting in how its built and can be used in other orientations and or designed so it can be clamped along the edges if you need unusual positioning, or depending on the normal mount points afford additional Y travel by clamping to table with the back edge flush, though I guess you could do that on any vise in a pinch though I think the castings around the edges are somewhat thinner
In any case I am at least at terms with going with a sort of middle of the road Taiwan made vise or maybe used kurt or the like if I stumble across something decent.
I am still overall a bit curious as to the styles of back "block" of the vise mounts where the block is keyed with a separate key, or the key is milled into the jaw block or entirely cast as the same part of the base. At this point I think I'm certainly going too far down the rabbit hole logically all exist for a reason and its more about the quality of the material and execution that matters.
certainly a lot of good info, and much appreciated.
