- Apr 23, 2018
- 6,821
Added: I do agree with you on the uni-strut, while very strong it isn't designed for a live load, it is designed for a static load, same reason I do not use tie-down straps to lift a load.
I think that's where the 2.5x factor of safety comes in, to allow for some jouncing of a live load (for lack of a better term).
Hilman is a chinese product distribution company, so just a reminder that chinese load ratings are a one-time limit: they will lift 350 lbs per trolley one time. Like Harbor Freight 2 ton jack stands or 4000 lb 1/4" chain. I feel a little better about the McMaster 600-lb made in USA trolleys that roll on a solid wheel without the chinese mystery non-spec (aka ABEC-0) janky bearings on the low-cost units. 600 lbs with a 2.5 safety makes a 240 lb safe load, that's good for the chucks and fixtures around the lathe and mill table. Two skates to mount a light duty electric hoist would probably handle anything for that purpose, depending on how the track is anchored. My ceiling is 13" high, so dropping anything on my head from that height could potentially put me on the short bus if wasn't there already.
