- Sep 9, 2014
- 90
Years ago a good friend, who is quite knowledgable in the use of lubricants, told me to never use moly oil or grease in roller bearing because it would act as an abrasive. He said it would be like putting very fine sand in the bearing. I've heard similar arguments from other sources. On a sliding surface, it's a wonderful lubricant since it has an affinity for metal and wants to adhere under extreme conditions.
Some moly greases are designed for use in roller bearings, but there is a specific formula. If you are unsure of the grease you intend to use, either research it to be sure, or use another high quality product to be on the safe side.
Good luck,
Ron
Good luck,
Ron
