- Nov 10, 2018
- 8
so, I have continued "working" on my spindle and the quill and tried to turn the nut down the shaft and I could turn the nut all the way down over the groove above the locking nut has "no stop". So how to know how much I need to tighten the nut, how big torque, should I just tighten it easily and lock it? and it's more, when looking at the lower bearing: it's lying on the lower part of the spindle this part has a diameter of 62 millimeter and that mean that this surface are covering both inner and outer part of the bearing!! i should make a spacer here as only work as a spacer for the inner part of the bearing of 40mm don't you think? here is the link to FAG's lower bearing https://medias.schaeffler.com/medias/en!hp.ec.br.pr/72..-B-2RS*7207-B-XL-2RS-TVP . where d2 is say 45mm. so 40mm x 1mm. spacer should be good for compensating and correcting for should be good and take a one millimeter thickness disk, when I am looking at Mikey's spindle I can see that it's different from mine, as you can see on this updated drawing :
