- May 3, 2020
- 153
More on the theory side of things, what could one use to grind that feature? Using the same methodology that is. I think most die grinders would be too large to fit, even those that are extended reach.2) An R8 collet has a .95" OD cylindrical feature (an inch long) on the opposite end (from the taper) of the collet. That is a precision diameter and mates with a precision ID in the spindle. The .95" diameter is part of the alignment system for the collet in the spindle. Stan simply said he wasn't going to grind it. He didn't say what the runout condition of the .95" diameter was or if he even measured the runout or diameter. Trying to fix R8 socket runout without understanding the condition of the .95" ID is foolish in the extreme. If the .95" diameter is not coaxial with the taper, the collet will bind and/or the collet will not be coaxial with the spindle axis of rotation (collet wobble).
It would also be pretty difficult to measure, needing a tenths indicator with a very long probe, something I'm guessing most people don't have (myself included!). All that to say that I'm not surprised I've yet to see the R8 taper ID mentioned in any DIY grinding videos.
