- May 3, 2020
- 189
The approach of basing the grease base oil thickness off the oil requirements for a similar application clicks for me, as the bearings in my spindle should have similar service requirements to a Bridgeport.
To that end I went looking around and found this ISO 46 offering from Lubriplate that seems readily available. Small 50g tube available from many retailers for around $10. Attached is the data sheet. A quote from it reads; "LUBRIPLATE DS-ES Lubricant is also highly recommended as a bearing lubricant for electrical motors, spindles and other mechanical devices where low torque, high speeds and long life are essential."
I also found an ISO 32 grease from Mobil called Mobiltemp SHC32 that looks like a great candidate as well, and a 12.5 oz tube goes for $13 from McMaster. I would say presently I'm between these two as more economical alternatives to Kluber.
I have no opposition to Kluber products other than price. I was going to take a look at their other offerings to look for a thicker grease than NBU 15, but their data sheets are locked behind needing a login to their site. Also their product search is very difficult to navigate, and I decided at that point to move on to other possibilities.
