- May 3, 2020
- 143
I'm also pretty perplexed about it. I could be thinking about this incorrectly, but wouldn't it be possible to swap to an angular contact bearing by assembling the two bearings and spacer on the spindle with thrust directions facing each other, and then shimming under the snap ring to apply appropriate preload?
At that point it appears to me that the bearing assembly would be held captive into the quill by the end nut. The lock nut at the top could then be adjusted to basically be finger tight and locked in place with the tabbed washer as to not place any force on the lower angular contact bearing.
I could be missing something obvious here. But in the perfect world of my mind it makes sense lol.
If that's even a correct line of logic, I also have no idea if any performance gains would be realized in terms of accuracy or rigidity.
