- Dec 3, 2023
- 96
No gearbox! it's a gear change lathe,.. meaning you take the cover off the back of the headstock and assemble a given gear set to change the ratio of main shaft/chuck revolutions to lead screw revolutions. Would I like a lathe with a gearbox?... A: Yes, but I don't have the room for a bigger lathe really atm.
The real twilight zone part is that I have a labeled diagram with all the assembled gears I used to cut the first batch correctly last summer, and those same gears don't produce the correct thread pitch now..... I must have made changes after I made the diagram and didn't note the changes, so the labeled diagram is wrong and the pitch is wrong because I plugged in the wrong lead screw pitch in the formula... which makes sense. God only knows how my parts came out correctly last time, but I must have figured it out then,... so I will figure it out again....
I have somewhere to go tonight and tomorrow is a religious holiday (college basketball) so I will get back to it within a few days and post the result.
