- Sep 24, 2014
- 926
Thanks for commenting Brooks!
I wish we were neighbors too, we'd sure have a lot of fun and PO the neighbors for sure!!!
Hopefully my threads give the impression of being there, i guess it's the next best thing!
My relationship with windex is strictly platonic....
It's a very inexpensive cutting agent.
I learned of it's value from Richard King's scraping class,
we used windex on our work when we were stoning the surface between scraping cycles.
you'd simply brush off the chips and give a couple squirts of windex, stone the area and wipe dry.
then another blue up on the surface plate for the next cycle.
it's cheap and effective.
Care should be taken to dry off the remnants after use, it may rust iron bearing pieces
I have used dollar store window cleaner for cleaning the bores and chambers of my war relic rifles after shooting corrosive primers.
the windex/water ratio in the cheap window cleaner neutralizes the corrosion left behind when the shell goes bang.
after the treatment of a patch with the cheap stuff, i'll run it down the bore until it comes back 90% clean
i'd then clean the rifle as normal and re-oil for storage.
corrosive ammo will literally eat your firearms if given half a chance!
thanks for reading!!!
Thanks for clarifying Mike. You know your in trouble if you start using windex as a medical treatment
