- May 7, 2023
- 2,242
Are you doing this on the lathe or mill?Crankshaft bore on flywheel for I.C. Model engine. I can turn the crankshaft to fit the bore. Might just have to break down and buy a US made reamer
Second best way to go about this is with a reamer in the mill.
Best way to go about it is to bore it on the lathe.
A reamer in a mill will give you a slightly (Depending) inaccurate bore alignment due to the mill head not being trammed true, and it is nearly impossible to tram it as true as you would get boring it in a lathe.
A reamer, in even a good well set up lathe will likely leave you with a slightly tapered bore due to several factors such as tailstock misalignment, radial inaccuracies in the tail stock drill chuck, and to a lesser extent the straightness of the reamer shank.
