Hi Guys,
Lots of very good comments. I am glad I ask. This is great. Thank you.
I too am/was VERY concerned with getting a tap that big started straight. Also, I had not even thought about using my CNC Mill, although I am a bit hesitant as the backlash is poor along the y axis so getting things exactly round is a problem. While my lathe will handle this, I am not so sure my tail stock chuck is big enough or strong enough to hold a tap this big. Anyway, thanks for the link to the $29 tap. Running it through after the single point turning (whether on the lathe or the mill) is probably a very good idea. Yes, it is a through hole. Yes, I will practice. I am thinking something softer than steel the first time. Al or maybe even Nylon. I did do some heavy steel facing on my Mill at one point. When I did this I set up a flood cooling arrangement. What a mess. I had to have to go back to that but might. Also, I needed better ventilation as I had purchase expensive DuPont coolant and its fumes were probably toxic.
Wow! I was not thinking of using my mill to turn the tap! I doubt that it is strong enough for that! Also, I am getting kind of old, so not for sure I could turn those crescent wrenches without standing on the lathe!
I did my own lathe VFD conversion and so the lathe will turn very slowly if need be. It jogs at about 7 RPM but obviously the power would be limited.
As far at the 7TPI this is no problem. If you folks have not seen it I built a spread sheet that will calculate all of the possible TPI values basically for any lathe. There are Macros that make it automated. The lathe sellers never list all of the possible gear combinations, of external gears plus gear box lever positions, so that you have a list of all of the possible TPI values that your lathe will make. For my PM1440GT with just the external gears that come standard with it there are 21200 possible combinations. Turns out that there are about a dozen gear and lever combinations that yield 7TPI. There are are almost 200 combinations that yield 7TPI to withing 1%.
Maybe the spread sheet is useful for your too. I posted an updated version last year and more recently I have been rewriting the macro that generates the table of values to make it more accurate. It works correctly, but has a feature that allows you to cause it to skip duplicates. This has a bug in it, so just run it in a complete table format. There are multiple spread sheets in the workbook for different lathe models. If yours is not there you just copy a sheet that is similar to your lathe and then modify it a bit. For example if you have a different set of external gears you can just change the values to your set. Likewise, if your gear box has different knobs or ratios this is pretty easy to fix. Anyway, there is Readme file to explain a lot of it. And if that does not work, then ask me.
Thanks,
Dave L
