Yes, but there is limited length of the threaded rod due to some other issues. My plan was to have nuts higher up that are used for a different purpose during the installation dealing ... with lifting the entire assembly to its final height. It, plus these others, holds a clamping plate that sticks out on both sides of the post to allowing one to lift the assembly using hydraulic jacks. Otherwise there is no place to push up from. After installation the lift place comes off and the nut could be run down a little to the threaded plate and tightened. So it would represent a lock nut to keep the rod from ever turning. When one has an assembly this long you better count on something being make with tolerances, or the measurement being off a little, or the house shifting positions changing the total distance a bit. So you need to have a little play during assembly of all of the tubes etc.just weld a nut to the plate
