- Feb 1, 2015
- 9,830
I have the G0602 and had the same problem. I found that the Shars tool holder have a slightly lower floor than the others I have. The Shars 250-101 will work with 12mm shank insert tools. The XL holders will just barely work with 1/2" shank tooling.
For most of my lathe work, I use either HSS or brazed carbide in 3/8". I do so because both can be resharpened whereas, when the edge goes on an insert, it pretty well is toast. I also use 1/4" or even 1/8" HSS tool bits, largely because they have less material and are easier to grind.
For a 10x22 lathe, 3/8" tooling isn't the weak link regarding rigidity. 1/2" tooling will add little. The main reason for using it that I see is because 1/2" (or 12 mm shank tooling is more readily available.
