Is this practice or the real deal? Just wondering. If practice experiment. Start with 150 RPM. First pass just do a witness cut so you can verify threads are correct. After that try .005 per side first few passes. Then taper off. The last couple of passes take .001 and do a spring pass.
You will be able to tell off the pass s too heavy.
FYI. This is just my experience. It does not matter if you plunge straight in or set compound at 29 or 30 degrees. I find I like going straight in as it is easer to get my desired depth straight away.
You will find your preferred method. Take what people suggest and incorporate what make best sense to you.
Cutting oil is my blood.
