I think the big take away from what Keith is trying to say is that more steps = smoother motion, which is very true with a stepper motor.
(skip ▼ and read the last bit for an actual answer)
Remember that steppers are nothing like a conventional motor and they "cog" instead of rotating smoothly (you can easily feel this when you rotate one by hand when it's not powered). The more "cogs" you have per rev (steps per rev) the smoother the motion will appear. Think of it as frame rate for a video, a picture is simply being displayed for a short time (like 1/60sec for a 60FPS (Frames Per Second) video) then it's being replaced with another VERY similar picture. The time between pictures is SO SMALL and the picture is SO similar that it appears to be fluid and continuous. The motor is similar, it's moving to a discrete step (a picture) and waiting a certain amount of time (FPS) to move to the next step (the next picture). The closer the steps are together (the more similar that two pictures are), and the lower the time between steps (FPS) the smoother the motion appears. Now, to control RPM, the drive increases or decreases the time between steps. As that time decreases the motor lingers longer at a certain step, like a picture being displayed for to long for a video), and as the time gets to large, the motor will noticeably "jerk" to the next position.
Now that that is cleared up (this guy talks to much and doesn't make ANY sense), you can see why more steps = smoother. HOWEVER (oh crap more talking), more steps = less torque. So it's balancing game. My 940 from the factory was set to 1600 and you can sertianly see it get "jerky" down around 3 IPM. When I get mine back together I'm going to change it from 1600 steps/rev to 2000 steps/rev to see if it moves smoother, and I can keep my current speed and acceleration. If I loose speed, I'm probably going to move it back to 1600.
PZ
