- Apr 23, 2018
- 7,051
Merely convenience, both can do a good job here.
GsT
I don't disagree at all. I think my tack is bent toward cost, necessity, and practicality. Carbide comes at a significant cost and is (for the most part) disposable. The benefit and the reason inserts are dominant is speed and time. On the lathe, the versatility and low cost of HSS is nice. In general, HSS grinds are capable of finer DOC and finer feeds, which are nice when a computer program isn't stepping up to your dimension for you. When they burn or get chipped, a pass on the hone puts you back in business. Chip an insert and break out another $10 bill, and if you're lucky, you don't have to re-make your part.
I feel differently about milling cutters for some reason. I don't use them for general purpose, but will quickly jump to a suitable insert tool when needed. I also like brazed carbide on the lathe, because they can be ground and re-ground a number of times and customized on a whim, making them versatile and recoverable when damaged.
