I could use a lathe. A bit scary to have that much weight turning round. But, it ought to fit into the 4-jaw chuck and I can see that it would have some advantages:
To finish this piece, I think I'll try my 1-1/4" insert mill. FS Wizard says I ought to be able to take about 1.5mm DOC at full width and ~1600 RPM. With almost a m/min feed rate. I'll start with about 1/2 that DOC.
- It would still be an interrupted cut, but the cutter engagement would occur in a better pattern (I think).
- I imagine I could get a micrometer on the bottom of the part. My mod vises for the mill hold the part 19 mm above the fixture plate...which is enough to get one end of a 1" micrometer underneath, but not a 2"-3" (or the metric equivalent. Although I could make some spacer blocks to elevate the mod vise pieces for mike access.
- It might be easier to indicate the part into the lathe chuck to make sure it's flat.
