- Dec 24, 2020
- 1,278
There would be an improvement if the tool was set at an angle that allowed too much of the insert to come in contact with the shoulder, causing the chatter he's experiencing. The same could be true if too much of the insert is touching the work when facing causing the chatter he describes.I worry about alignment for parting and threading. Pretty much anything else, I'm just "ballpark". I've done it every which way and there really isn't a discernible difference when using carbide (because it will have the same edge and clearance all around) while conventional HSS cutters can be more picky because they are not usually symmetric. Nothing wrong with setting everything square, it's just not a requirement, nor would I expect one to see any improvement from it.
GsT
Someone with your experience won't usually make those mistakes, but someone just learning might easily run into that problem and not know any better. That's why I described what I did...eliminate the mistake variable and put that particular tool parallel to the chuck. That way we know the geometry is at least ballpark close enough and if he's still having a problem, it's time to look at other factors. It also lets him do the two operations he's talking about without making any changes....win-win. If it doesn't help it's still not going to hurt, which is important when trying to fix a problem.
