- Feb 1, 2015
- 10,110
Personally, unless I was totally cramped for space, I would stay away from the combo machines. You can't combine the different machines without some compromises. It is also nice to be able to go from one machine to another without having to tear down your setup.
As to specific machines, it is hard to speak to that without knowing what the space and budget limitations are. The first step would be to lay out a floor plan. I did this with simple boxed to represent the machines and other equipment. Regarding a lathe, it is good practice to keep the left side of the lathe as free as possible to permit longer stock to be entered through the headstock. For the mill, it is good practice to keep the envelope clear at the furthest extremes to left and right of the table travel. Ideally, you would also want additional space for longer work. Desks or workbenches can fit under those spaces if necessary.
Unless you are anticipating larger work, a 10x22 lathe will work nicely as will some of the bench top mill/drills. I have the Grizzly G0602 and it has been relatively free from problems. The RF30 or clones are also a capable machine. The PM machines are arguably a step up albeit at a step up in cost. There seems to be a common belief that bigger is better. I don't subscribe to that. True, a bigger machine generally is more rigid and higher power but they are more expensive, they require more space and power requirements are greater.
