- Dec 18, 2022
- 2,859
I have had 1 or 2 issues which were problematic that required a fix and PM backed them up without complaint, they provide a 3 year warranty and they support their customers. Fit and finish, the castings tend to be a bit rough and the filler a bit liberal but over all I have had very good results from my 2 machines and most of the things I doctored on were personal preference. The clean up and de-burr took some time. I have a Taiwanese wood lathe and it does have a better quality of casting and the body filler is minimal; but for the price difference I am happy with the Chinese machines I have and haven't had issues attaining the accuracy I expect. Like I said the one thing that would sway me over to the Taiwanese PM-1236T is the gear box which would eliminate the use of change gears for threading,My thoughts exactly...I'm definitely interested in the DRO feature, and it makes sense to have common functionality.
Just one more reason to buy both machines from the same company. I'm hoping that I could also negotiate a multi-machine discount.
And the anti-vibration pads are a good point, I'll keep that in mind.
Regarding Chinese vs. Taiwanese, how much of a difference in accuracy are we talking about? Is it more of a fit & finish issue? Are these 'quirks' correctable? I'm used to buying offshore tools (both of my bandsaws and my disc/belt sanders, to name a few) and then spending a day or two 'blueprinting' them to correct any minor deficiencies. Of course, with a lathe or mill I expect it may be a bit more time consuming. Is the price differential between the two that drastic? If we're talking savings in the thousands than it's worth it to me. And of course I want accuracy, and more precision is better, but realistically the parts I'll be making won't be aircraft grade, lol.
Your likely looking for the 833 size mill and the Chinese PM-30MV and the Taiwanese PM-833TV which is in the 2000 difference catagory, lots of info on both machines to look at on PM's site and many here have said good things about both. I will say I have the 940V but originally wanted the 940M difference being a gear head verses a variable speed belt drive and I have found the variable sped to be a great machine with plenty of power, it's another item you'll want to research.
