By the way is that a CNC conversion on the X-axis?
Yes. mine is cnc on all axis.
Sorry for the late reply. But looks like you where quite busy
I had some trouble with my machine as oil was comming down the spindle. Since I had to change the oil-seal I decided to change all bearings as well and this was quite a journey.
Getting the bearings was not a problem since lukas allready listed them in is thread on the german site. But the upper spindle bearing was really hard to find.
Reassembling went fine and everything worked great, but only for a day or two. Then the oil started dripping again.
Turns out that the oil seal was installed backwards by the factory and i went along with it, without much thinking during reassembly.
The only thing that was a bit strange was that the bearing inside the gearbox reached about 100°C when I looked at it with a theramal camera.
So the second time changing the seal was way quicker since i allready had experience
And this time I went with a better seal for higher temperatures but since the seal was put in the right way the bearing didn't get as hot.
If you don't have done it allready I really recommend an oil change. The factory oil was really a brown stinking soup.
And if you need pictures from inside the gearbox, I have lots of them
