Some more shop equipment found in my main workshop
Here is my work station. Two solid maple work benches with workspace between them. My computer is on one bench with a stack of Gerstner tool box, bottom one on rollers. Whilethe other bench has a riser with three Gerstner tool boxes on top.Originals lost to the fire. There's a small granite layout plate with a 12” height gauge.
A 55” RollCabs roller tool box contains accessories for CNC Machining Center. AM Scope Stereo Microscope with 12”viewing monitor.
Two Durham cabinets, originally gray, painted them blue to match my garage color sceme. My gauge blocks, sine plates, micrometers, drills bits, end mills, taps, etc stored inside.
A 24” by 36” Black Granite Inspection plate with home made stand.
US Industrial 16” by 40” Lathe with 3” Dia spindle hole, 12” four-jaw chuck, 10” three-jaw chuck, Bisen 5C front key, and Gator 10” six jaw chuck.
Welding table with Lincoln 225 Precision water cooled torch TIG welder, and Weld Tec torch watercooler. Lincoln Power MIG 215 welder, and older Airco 180 AMP stickwelder sit on wheels, And can be rolled around the shop or other garages. ..
US Industrial 12” by 24” Three-Axis power surface grinder 12” Dia wheel and power over-wheel diamond dresser.
US Industries 6” by 18” power Two-Axis suface grinder 7” Dia wheel also over-wheel diamond dresser. Although it has flood coolant. Most likely I will never use it.
Monaset Cutter and Tool Grinder. This is a high quality Taiwanese copy of the original designed Cincinnati Monoset (spelled with an “O” rather than an “A”) Cutter Grinder. And where manufactured in the 1940's through the 1980's. Have two sets of spring collets, a six jaw precision chuck, and 4” Dia Magnetic Chuck. Fantastic machine for all kinds of cutter sharpening. It incorporates the ability for sharpening the helical cutters using internal cams. Without the use of a finger guide. I made hardened valve guides using this machine along with facing off valve seats..
Deckle SO Single Lip Cutter grinder. May be small but a very versatile machine to expediently sharpen cutting tools, mainly single lip. Deckle stopped making them several years ago,, word has it they are once again producing them.. There are a number of cheap Chinese knock offs,, not good quality today.. And not worth owning..
Dake Manual 50 Ton Hydraulic press...I've always wanted one of these in my home work shop.. Either side has a sonic parts washer,, small and a larger model. Great way to clean smaller parts. There an array of C-Clamps up to 12" mounted behind the press. Along with nylon straps and eye-bolts to 1 1/4" thread dia
72” RollCabs Combination Roller Cabinet.. I own several Snap-On roller cabinets and these are the same quality.. Actually these are re-badge Extreme tool boxes..
This drawers have some of my adjustable Cresent Wrenches from 4" to 24"
I have 39 Milwaukee Power Tools from hand drills to Chain Saws. When not in use I store the lithium batteries in this Mesa Safe with a fire rating of 1,700 degrees F for two hours.. There's a six station charger for M12 and M18 batteries. With a timer mounted outside the Safe.. I have two auto rewind air hose reels plus four hoses located around the shop
Mitutoyo 14" optical comparator
BadBoy sandblast cabinet Both suctions and pressure feed. Along with dust collector
Graymills Parts Washer.. In Blue, painted by the OldCarGuy...
