I've had the same question as
@brino. So, would this be the answer? The figure of merit for a vice is that the part doesn't move one you tighten it down?
I just assumed that as long as the fixed jaw is flat, and the vice is stout enough, it could be shaped any old way. You stick a part in and clamp down on it, often sticking a piece of dimensionally unknown scrap in there to insure that it indicates against the fixed. Who care if the movable jaw is straight at that point? Once clamped down, and you've indicated the part if necessary, you don't take the part out until it is done. Again, as long as the part doesn't move in the vice while you're cutting, why would you care that the fixed jaw is not perfectly perpendicular to the sides, or perfectly parallel to the outside? Why would I care that the top of the vice is perfectly flat once I've bolted it to the table?
