Also called cup center. Can be handy .
I will get one of those inexpensive kits that have interchangeable tips. I wanted something that I could use on pipes/tubing... so seeing that there is a set that covers different applications, I will go with that.
And to consolidate the stuff I have been getting for the lathe...
Got a few solid carbide small boring bars... just to practice... found those on eBay.
15amp multiple outlet. Same one I have on the HF9x20. I will fix this one to the side of the toolbox.
Was able to find new old stock (NOS) chucks... US$190.00 each... came out to US$505.00 for both with shipping and taxes included. Got them from
HH Roberts out of Canada. Wanted chucks with integrated/integral threaded setups in the hopes that these do not protrude more than the stock units...
New (NOS) 5” 3-jaw Bison 2-piece jaw chuck with integral threaded 1-1/2”x8 tpi mount
New (NOS) 6” 4-jaw Atlas chuck with integral threaded 1-1/2”x8 tpi mount - stock one that I have is 8"... but 6" will do just fine. If I need to work something larger I can always take it over to the Grizzly lathe...
Used Buck 5" 6-jaw chuck. Well, two in fact... I just need to make a backplate for one of them. Thanks to
@mattthemuppet2
ER32 collet set - 1/16"-3/4"
Cheap Türlen Test Dial Indicator 7 Jewels High Precision 0.0005" - I break these so often that is not even funny... this is my 3rd or 4th... I have a better one that I am always afraid to take out of its case...
30X Jewelers Loupe
Pending stuff:
- DRO - I have some iGaging iP54 Electronic Digital Scales that I never used for the G0704... and since I went CNC with that one, I will not need them. Also, I still have the TouchDRO box I made... and the tablet is around here somewhere... Will see if I can repurpose those and do something similar to what Matt did ( Link to his setup ).
- Redo the wooden wheel for the ER32 collet drawbar. The one I made was just to practice. Now I want to make it out of some better wood...
- Need chuck keys for the Jacobs drill chucks... those were missing. But I am not close to the lathe. Will order those when I am in Orlando and can measure the size.
- Need to make the gib for that extra cross slide
- MT2 tapered drill chuck. Just want a new one for when the lathe is done. But pretty sure that I will better off restoring the Jacobs chuck that came with the lathe
- < this one left blank on purpose for future entry >
