Last year I bought most of the machines from a guy's basement machine shop. I also agreed to clear his basement of all machines, by taking them up the stairs. I thought I'd post a few highlights of that move, and answer questions about moving heavy equipment...
These are the machines I moved:
Leblond 15X60, 3400+ lbs
BP clone 2400 lbs
heat treat furnace 500 lbs
surface grinder, 2000 lbs
and 7 or 8 other machines under 500 lbs...
The mill and the lathe were completely broken down to components and moved as parts. the Surface grinder had to be moved intact.
I used both a gantry crane and a joist crane to break down machines and prep them for moving. One mistake I made was that my gantry crane couldn't move from one side of the basement to the other, as the support beam was 5" too low for it. I had to make a new top beam and change the geometry slightly to allow it to move under the beam!
The modified gantry crane
using the joist hoist to raise the 900 lb bed up and out the window. The wooden cradle is there to allow it to be moved in several steps.
