- Jul 31, 2020
- 765
You might want to check into swapping out just the threaded shaft, and leaving your slide. You will need the the end piece where the DRO attaches.Problem there is I scraped the compound slide and it's mating base to eliminate chatter (and it's made a huge difference) and the kit from LMS comes with a new cross slide. It took me over 20 hours to scrape the compound slide and I'm not looking forward to doing it again. The reason they supply a new slide is because they changed the threads per inch to match the DRO equipment.
